configure msrp ports traffic-class delta-bandwidth
configure msrp ports [port_list | all] traffic-class [A | B] delta-bandwidth percentage
Description
Configures delta-bandwidth value per traffic class per MSRP port.
Syntax Description
msrp Multiple Stream Registration Protocol.
port_list List of ports in the switch.
traffic-class Traffic class.
A Traffic class A.
B Traffic class B.
delta-bandwidth Delta-bandwidth percentage (range 0 to 100, default 75 for class A, 0 for class B).
Default
Class A: 75, Class B: 0.
Usage Guidelines
The delta bandwidth configuration limits the amount of bandwidth that can be used by the given stream reservation class. Each class is allowed to use a maximum of its delta bandwidth plus the delta bandwidth configured for each of the higher classes. For example, if the delta bandwidth for classes A and B are configured to 10 and 10 respectively, class A streams can use up to 10 percent of the link bandwidth, and class B streams can us up to 20 percent of the link bandwidth. The sum of the class A and B delta bandwidth values must be less than 100 percent.
# configure msrp ports all traffic-class A delta-bandwidth 50
# configure msrp ports 1-5 traffic-class B delta-bandwidth 0
This command was first available in ExtremeXOS 15.3.
Platform Availability
This command is available on platforms that support the AVB feature pack license and have it installed. For complete information about software licensing, including how to obtain and upgrade your license, and which platforms support the AVB feature, see the Switch Engine v33.1.1 Licensing Guide document.
